1988 JD 850
/ 1988 JD 850 #1
jimrob
Need to know about after market engine overhaul kits
/ 1988 JD 850 #2
jimrob,
Are you doing a complete motor over haul on a JD850,also is there engine damage.
Thomas..NH /w3tcompact/icons/wink.gif
/ 1988 JD 850
I belive I have a busted piston. So I need sleves, pistons,Bearings, and gaskets
/ 1988 JD 850 #4
Jimrob,
Any idea what caused the problem? I have an 850 also (I think older than yours).
/ 1988 JD 850
Pulled head today. #2 piston did not come up as high as the rest (.050 down). Possably wrist pin? Will know tomorrow.Still need to know where to buy Piston, rings, bearings, and gaskets.Tractor has 1565 hours. Don't know the cause. Will guess more tomorrow when I pull the pan.
/ 1988 JD 850 #6
jimrob,
Have you check out Deere Creek Equipment website. www.dcequip.com They might have the parts and answers to your needs.
/ 1988 JD 850
SPun bearing on #2 rod.So I need a CRANK ,Rod, pistons, sleves, bearings, and gaskets.Can't tell why bearing failed(lack of lube I'm sure but why?)If anyone knows of aftermarket parts I would like to Know. dcequip.com is dealer only.
/ 1988 JD 850 #8
jimrob,
Farm & Country..Central Tractor do sell after market parts and they do have a website.
I wish I could tell you if they have parts which you need,for my catalog old.
/ 1988 JD 850 #9
try the "engine room" in onset,mass they are supposed to be able to get all kinds of factory parts c-ya steve j.
Deere 160G (A64126)
Deere 160G (A64126)
John Deere 7810 (A64126)
John Deere 7810...
2016 JLG T350 (A64126)
2019 Sellick S80 (A64126)
2019 Sellick S80...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
John Deere 694 (A64126)
John Deere 694...
