1986 kubota L345dt no start
   / 1986 kubota L345dt no start #1
chickadee
moultonbrough n.h.
kubota L345dt
replaced starter both red lights on dash work!! glow plugs work!! can start by jumping between small starter wire an large 12v wire?
   / 1986 kubota L345dt no start #4
Welcome to TractorByNet!
We moved your thread to the Kubota Owning & Operating forum. :)
   / 1986 kubota L345dt no start #5
Does it have any "neutral" switches, say on the pto, rocker "go" pedal, etc. That's what it sounds like to me if every other system is "go".
The newer ones have two on the seat switch as well.
f.
   / 1986 kubota L345dt no start #6
Probable cause's....
neutral safety switch,
ignition switch,
make sure pto is not engaged,
fuseable link to the starter blown.
   / 1986 kubota L345dt no start #7
There is a S-shaped exposed 30-amp fuse mounted on the firewall that gets corroded terminals and no longer passes enough current to operate the solenoid. Powering the solenoid by jumping it bypasses the corroded fuse. For my L3445DT I bought an in-line 30a replacement fuse and wired it in - problem solved.
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2017 POLARIS RANGER 500 EFI UTV (A51247)
2017 POLARIS...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
New Long Forks (A53002)
New Long Forks...
New Holland B95 Backhoe (A50490)
New Holland B95...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
