1986 kubota L345dt no start
   / 1986 kubota L345dt no start #1
chickadee
moultonbrough n.h.
kubota L345dt
replaced starter both red lights on dash work!! glow plugs work!! can start by jumping between small starter wire an large 12v wire?
   / 1986 kubota L345dt no start #4
Welcome to TractorByNet!
We moved your thread to the Kubota Owning & Operating forum. :)
   / 1986 kubota L345dt no start #5
Does it have any "neutral" switches, say on the pto, rocker "go" pedal, etc. That's what it sounds like to me if every other system is "go".
The newer ones have two on the seat switch as well.
f.
   / 1986 kubota L345dt no start #6
Probable cause's....
neutral safety switch,
ignition switch,
make sure pto is not engaged,
fuseable link to the starter blown.
   / 1986 kubota L345dt no start #7
There is a S-shaped exposed 30-amp fuse mounted on the firewall that gets corroded terminals and no longer passes enough current to operate the solenoid. Powering the solenoid by jumping it bypasses the corroded fuse. For my L3445DT I bought an in-line 30a replacement fuse and wired it in - problem solved.
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
2016 LT63 Towable Light Tower (A51691)
2016 LT63 Towable...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
