1977 ford 550
/ 1977 ford 550 #1
johninrochester
1981 ford 545
I have a hydraulic oil leak coming from the front shaft under the radiator , you can see the oil coming out when running, is it maybe a hose I hope? Or something loose, hoping its not the pump.
Thanks any input would be great
John
/ 1977 ford 550 #2
It could be a cooler hose but that would probably keep leaking after the tractor was shut off. It would leak until the cooler was empty though. If it is leaking only when it is running it sounds like a shaft seal. it shouldn't be to big of a deal to repair really. Most of the time if the pump is working properly just the seal needs to be replace and can be done without removing the pump in some cases.
/ 1977 ford 550
Thanks, it ended up being the cooler tank, now I'm in for a new radiator $400 plus
UNUSED 2026 INDUSTRAS AMERICA 227T TILT BED TRL (A62130)
UNUSED 2026...
2021 Gulf Stream Kingsport T/A Travel Trailer (A61569)
2021 Gulf Stream...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
110 GALLON SPRAYER TANK (A62130)
110 GALLON SPRAYER...
2019 Toyota Mirai Sedan (A61569)
2019 Toyota Mirai...
2018 Hustler Super 104 Zero Turn Mower (A63116)
2018 Hustler Super...
