1975 Ford 4000 ignition ?
/ 1975 Ford 4000 ignition ? #1
banc123
Bronze Member
Florida
I have 1975 Ford 4000 tractor. Haven't used it since November when I planted the fall plots. Went to crank it last week and all it would do is turn over, no firing. I drained the carb and put new fuel in, same results. I started with the carb, got a rebuild kit and rebuilt it. No change, same result. I learned something after I had rebuilt the carb that if you spray ether into the carb and it doesn't fire up for at least a few seconds, its not the carb
I moved on to the coil and the distributor. The distributor cap is new last year.
If I test the voltage on the + terminal and ground terminals on top of the coil I get about 8 volts.
If I leave the meter on the + terminal and use the - on the battery or the block, I get 12.75 volts.
So I'm thinking I have a bad coil and take if off.
If I put a volt meter on the + wire that I unhooked from the coil and the black wire I unhooked from the coil that runs to the distributor I get the 8 volts again. So no coil in between, just the + wire that I unhooked from the coil (it runs to the solenoid) and black wire I unhooked that runs to the distributor. about 8 volts.
Now if I leave the volt meter on the same + wire I unhooked from the coil and ground the volt meter to the - on the battery or the block, its the 12.75 volts.
Now I'm thinking maybe its not the coil maybe its getting a bad ground from the distributor or the distributor is bad.
So I tried to replicate a coil test I had read about. With the coil + wire back on the coil but wire that runs to the distributor off, I unhooked the center distributor wire that runs to the top of the coil from the distributor. I took a spark plug out and attached it to the end that normally goes to the center of the distributor. I attached a ground wire around the threads on the spark plug. According to the test, if I touch the end of the wire I attached to the base of the spark plug to the - on the battery, the spark plug should fire and throw a spark. Nothing ...zero spark. Back to thinking the coil isn't working unless I did the test wrong.
So I did something you're probably not supposed to do....trying something as a "what if" vs knowing if its the right thing or safe.
I know my + going to the coil is good, so I left it plugged in but ran a jumper from the - on the battery to the terminal on the coil that normally runs to the distributor. Now I KNOW I have a good + and - at the coil. So I try the spark plug test again with the spark plug hooked to the end of the center coil wire and a ground wire attached to the spark plug base.....drumb roll.......
Nothing, no spark.
So I put the volt meter back on the coil when KNOW its getting a good + and good - connection right to the battery. It still reads 8 volts from the coil terminal bolts, even though its direct wired to the battery. If I move the - volt meter wire to the - on the battery or the block, it goes back to 12.75 volts.
Apparently even with the coil direct to battery if you read from the coil terminals it will read 8 volts, but soon as you ground it to anything off the coil its 12.75 V
Now is when a mechanic/guru probably says, "No kidding, as the current goes through the coil and you read from the coil terminals, its going to be less" , not sure, thats my guess.
So I'm still a little stumped. I ordered a new coil anyway.
Here is the summary of what I know
1. Turns over fine, no fire at all with ether.
2. + coil wire will read 12.75 volts when grounded to anything but the terminal that has the wire that runs to the distributor. On the terminal ends of the coil, its 8 volts.
3. With the coil off and the volt meter on the + wire that runs to the solenoid and the wire (no longer attached to the coil) that runs to the distributor its 8 volts.
4. Coil terminals only read 8 volts even when wired directly to the battery.
5. If I hook up a spark plug to the end of the wire that comes from the center of the distributor and run a ground wire from the base of the plug and touch it to the - on the battery....no spark.
Any thoughts or suggestions ? Thanks
Thanks, I couldn't really see down into the distributor but its possible. When Pull the cap off there's a cover over the insides and I didn't pull it off, so it could be messy under it I guess.
I ordered a coil and tune up set, hopefully thats it.
Thanks.
/ 1975 Ford 4000 ignition ? #4
banc123 you may also want to grab a book on kettering ignitions.. spark occurs when you break the ground after having first charged the coil.
do your test differently.
bat+ to + on the coil
center tower spark plug wire to a spark plug
wire from base threads of spark plug to bat - ( chassie ground )
now take a common lamp on/off switch.. wire - side of coil to one switch terminal, and the other switch terminal to chassie ground.. now take an ignition condensor and wire it across the 2 terminals on the switch...
throw the switch back and forth.. that's your 'points' the spark plug should spark every time the switch opens ( off position ).
btw.. you can do this test with a 12v lantern battery, the spark plug, coil, condensor and switch.. no need to involve the tractor.. :)
soundguy
PT 300 Gal Poly Tank (A64912)
PT 300 Gal Poly...
2013 Ford Explorer SUV (A66738)
2013 Ford Explorer...
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A66736)
2014 International...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
218799 (A65057)
218799 (A65057)
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
