1974 Massey Ferguson 175 Diesel keeps blowing oil from the exhaust...
   / 1974 Massey Ferguson 175 Diesel keeps blowing oil from the exhaust... #1
jsc1500
Stem, NC
Massey Ferguson 175, Massey Ferguson 35, Ferguson 35, Ferguson 30, Farmall 100
Seems that when the tractor has been used for a prolonged period of time, or even shortly under continuous or heavy pressure that it wants to spew oil from the smoke stack onto the hood and ruin my current shirt. Any clues on why it is doing this? I know she's old, but she's still a beast around the farm. I can't afford to have it blow up or be in the shop for months. What should I do? Any simple fixes or ways to check for possible solutions?
Thanks,
Jeff
   / 1974 Massey Ferguson 175 Diesel keeps blowing oil from the exhaust... #2
Does the tractor use oil? may be time for new sleeves and pistons. Light load use will cause wet stack diesel slobber too, especially if thermostat is too cold or stuck open allowing engine to run too cool.
   / 1974 Massey Ferguson 175 Diesel keeps blowing oil from the exhaust... #3
Hours on engine? Oil change history? Engine temp when this happens? ....... Provide as much detail as you can.
   / 1974 Massey Ferguson 175 Diesel keeps blowing oil from the exhaust... #4
If your blowing oil out the stack it's time to start saving up for an overhaul ,Time to back down the rpm's and work load .
   / 1974 Massey Ferguson 175 Diesel keeps blowing oil from the exhaust... #5
I think you are right. These old Perkins are easily rebuilt. I would figure $1k if he did it himself and $3k by a shop? Done right, they are good to go for another 5 to 10k hrs
2015 JCB 550-170 Telehandler (A51573)
2015 JCB 550-170...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
UNUSED INDUSTRIAS AMERICA 12F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
