1974 JD 310 A no hydraulics
   / 1974 JD 310 A no hydraulics #11
Two splits possible, forward of shift levers or behind shift levers.
You want to do the first if you are after the clutch, same as TX Jim says between engine and clutch housing
I have a JD 2030 I need to replace the clutch housing on later when it warms up.
Hello again thanks for the help guys. It turns out my problem was a broken clutch disk, all the spring broke away from it and we're laying in a pile at the bottom of the clutch housing .here are a few pics it was actually easier to accomplish than I thought. image.jpgimage.jpgimage.jpgimage.jpg
   / 1974 JD 310 A no hydraulics #13
I'm glad you found your tractors problem. I'm glad I'm not the one repairing it.
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
Loader Bucket (A53421)
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
1994 International 3800 Bus (A54814)
1994 International...
