1972 V6000 Kubota
/ 1972 V6000 Kubota #1
Anonymous Poster
Epic Contributor
It looks good in the paper (for sale). Is it a good deal? $2400. Will it take a half-acre to turn? 12 HP diesel sounds adequate for my two acre plot. I plan to mow the big areas, haul wood and grade the driveways. What doe you know about this gem?
/ 1972 V6000 Kubota #2
Not enough information, Jeff, but I assume you missed a keystroke by one space and meant a B6000. And it seems that almost any tractor in operable condition will bring $2 to $3k, so it'll probably sell all right.
Bird
/ 1972 V6000 Kubota #3
Jeff,
Did you mean a B6000?
If you meant B6000 or could it have been a B6000DT than it sounds like 12.5 hp,and the year I believe they were introduced to the comsumer was early 1973.
The another B6000E which also 12.5 I believe was introduced around 1974.
I could be a tad off with this fact,but if I recall the B5100E/DT was the replacement for the B6000DT & B6000E in 1978.
I'm not sure if that model has power steering,so have a good grip while turning and hauling plus fixing the driveway etc.. /w3tcompact/icons/wink.gif
I don't think you could go wrong for that price,but double check for noise & leaks,also the shape of the mower.
$2,400.oo a good down payment towards a new Kubota tractor./w3tcompact/icons/smile.gif/w3tcompact/icons/wink.gif
Hope you had a pleasant weekend and stay /w3tcompact/icons/cool.gif
Thomas..NH
/ 1972 V6000 Kubota #4
Jeff,
I happen to have a sales brochure on the B6000. It is a 2-cylinder diesel 12.5 hp tractor available in 2wd (B6000E) or 4wd (B6000C). Note that most other Kubotas use a "D" suffix to indicate 4wd. It had a lot of optional equipment available (front end loader, tillers, etc) but you will probably have a hard time finding any B6000 specific items if they don't come with the tractor.
PTO Direction: Excluding "Grey Market Tractors (tractors not built to US specs but are here nonetheless)", the B6000 is the only Kubota compact tractor that I know of that has the PTO turning in the non-standard direction. This could be critical if you plan to use 3-point hitch PTO driven equipment. If you do a search on "B6000" someone had previously posted about a device that reverses the PTO direction allowing you to use standard equipment.
PTO Speed: Most PTO equipment for US tractors operate at 540 rpm. According to the B6000 sales brochure, the B6000 has a 3-speed rear PTO. At 2700 rpm you have your choice of 560, 840, or 1350 rpm. It would probably be acceptable to operate the 540 rpm equipment on the 560 speed. I'm reasonable sure that the B6000 doesn't have a tachometer so that an exact engine speed of 2700rpm would be difficult to achieve with precision anyways.
Cooling System: I'm pretty sure that the B6000 has the "thermo-siphon" cooling system. I've posted plenty on this before. It is a good system but has peculiarities that you need to be familiar with. Search the archives or ask me for details after you purchase the tractor.
Will it do the jobs you are asking of it? Here are my opinions...
Hauling Wood: I don't know how you intend to haul wood. Assuming that it doesn't have a front end loader, then if you are pulling a trailer then it should do fine.
Grade the driveways? Its 3-point hitch should handle a 5' scraper blade or a 4' yard box just fine. It might even handle an extra foot on each item.
Mowing? If it doesn't come with a mower, then here will be your biggest problem. The mid-mowers are generally pretty good on these, if it has one (parts are available, but expensive). If it comes with a rear 3-point hitch mower (either finish or rotary cut) then that mower should do fine as long as it is in good shape. However, if it doesn't have a mower, or if you have to replace it, then you will eventually run into problems because of the PTO direction.
Hope this helps,
Kelvin
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A62130)
2008 INTERNATIONAL...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
DEERE CLIMBER (A62131)
