1972 MF 135 Diesel Starter safety question
   / 1972 MF 135 Diesel Starter safety question #21
I think they are pretty easy. Big gauge wire goes from battery + to big lug on starter solenoid. Big gauge wire from batter - goes to tractor engine bolt ground.
Then wire(14-16 gauge) then goes from the S or start position on a standard switch or any push button momentary switch to the neutral safety switch that is under the battery and under the black regulator, and then out of that onto the little bolt or spade on the starter solenoid.
A hot wire then goes from the battery +, 14-16 gauge is fine, to the + or hot label on the switch or the opposite side on a momentary switch.
That is it. It is now wired to start, but not charge. This is a simple solution that will give you a safe way to start the tractor. It is then fairly easy to add the starting circuit later, light circuit, glow plug, etc.
It would be a good idea to fuse the hot wire that goes from the battery to the switch as it is always hot and if it ever rubs through the fuse will blow.
If you need me to draw that up or show a picture of mine, I can. If you have a switch already and you have a question, post a picture of the back of it and we'll guide you how to hook it up.
Good Luck
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2008 CAT 287C (A50854)
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
