1970 JD 110 harness routing...
   / 1970 JD 110 harness routing... #1
rtsherrod
Fenton, IL
2011 X324; 1970 John Deere 110
Hello all,
Does anyone have a harness routing diagram for a 1970 square fender 110?
The original harness has been hacked and modified over the years. I ordered the replacement harness today and will install it as soon as it arrives.
I want protect my investment by avoiding pinching or catching in moving parts. The factory routing is the best, but I don't trust the current routing given it's history.
Thanks,
Bobby
   / 1970 JD 110 harness routing... #2
Go to john deere's website and create an account. You can register your tractor and then log onto JD Parts. They have all of the parts and wiring diagrams in a printable format. I have a 1969 112 which is nearly identical to the 110. I replaced all the wiring by just cutting olne out at a time a rewiring it. A grounded out wire is a good way to start a nice fire.
   / 1970 JD 110 harness routing... #3
One last thing: If your machine doesnt already have it, pick up a battery cover kit from your JD dealer. They are free and will keep the gas from hitting the positive battery terminal and blowing you to the moon!
Hello GreenRules,
I have the routing figured out, just need to tear out the old harness and install the new one.
I have my 110 up on jack stands in the garage to work on it. I'm replacing the brake band. Then I will be replacing the secondary drive belt, tightening up the steering, fixing a loose RH rear hub, installing front lift rod (getting off of eBay soon), and replacing the magneto alternator to restore the charging system. I also already picked up the battery cover, but thanks for the tip anyway.
Then it will be time to hook up the 37A snowthrower I picked up in from Central Wisconsin Coop last Friday. It was a long, but fun trip.
I saw on another post that you have a rear ballast box for your patio tractor. Was it an original accessory? The 37A included a battery box just like yours, but rusty and minus the lid. Was green the original color of the ballast box and did it have a logo decal applied?
Also, what do you use for ballast?
Thanks,
Bobby
   / 1970 JD 110 harness routing... #5
The box is a genuine JD accessory and I believe it should be green, but I have only seen one other before. I have lead wheel weights in it from balancing tires. Like 50# worth. My 112 has a limited slip differential and it really digs in.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
