1968 Ford 5000
/ 1968 Ford 5000 #1
Kimocruise
1968 Ford 5000
Hi there. I'm new here. I have a 1968 Ford 5000. It sat for like 2 months. Now it will turn over but not crank. Like it is not getting fuel. Battery is fully charged and strong. Just topped off fresh fuel. So its not that. Am checking fuel filters. Any suggestions?
/ 1968 Ford 5000 #2
IF it will fire on starting fluid, it's fuel issue. If not, ignition problem. Check that you have power to coil, dry distributor inside & out, points good & proper gap.
/ 1968 Ford 5000 #3
Is your 5000 gas or diesel?
If diesel fuel filter is a place to start check for water, sludge, etc. in the filters.
/ 1968 Ford 5000 #4
Was it supposedly in running condition when last parked? Is it the gasoline type or the diesel? If diesel - do NOT use starting fluid.
/ 1968 Ford 5000 #5
Also if diesel, look at the kill lever on the side of the injector pump, if there is a button in the center press that then try to start it...
/ 1968 Ford 5000 #6
Does it have a high/low range lever? Fords wont start in gear.
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
Used Landpride GR1525 Stump Grinder
Used Landpride...
1992 Jeep Cherokee (MPV), VIN # 1J4FJ78S6NL230132 (A65563)
1992 Jeep Cherokee...
