irwin
Veteran Member
A little update...
Per several of your suggestions, I put a meter on the battery to see what the charging system is doing. So here it is.
At slowest idle, the generator is putting out just barely over 12 volts. Then as I increase engine RPM, the charging voltage increases comensurately up to about 13.6 volts at about 80% throttle. Increase the throttle past 80% and the charging voltage abruptly drops back down to just over 12 volts. Once this voltage drop occurs it sticks there, regardless of what I do with the throttle thereafter.
So now what do y'all think?
Thanks!!
Mmmm, That doesn't sound right. I'd say you have a charging system problem..it' doesn't appear to be severe, yet.... but it's not right.
