1964 Ford 4000 4 cylinder repair/restore
   / 1964 Ford 4000 4 cylinder repair/restore #11
I had one of those carbs on my '41 Farmall. It was a Marvel if it worked. I fabbed up an adapter plate, got a 'U' bent length of steel tubing and mounted a real Rochester single barrel carb in the normal (downdraft) position. Problems solves. A little brazing and some drilling and a new throttle and choke cable and it was good to go.
Those carbs flat suck.
   / 1964 Ford 4000 4 cylinder repair/restore #12
5030- I agree that this carb is difficult to tune (compared to my 1943 Case SC). I have cleaned/rebuilt several carbs (including this one) and after lots of float adjustments, cleanings and mixture screw adjustments, I have found that I have it dialed in pretty good but I have to use the choke a little bit to fine tune the mixture. It starts well when very cold outside, but that choke knob gets moved around a lot...
Thanks for all the info gents. It is definitely not a drain plug. it is threaded hole inside the carb. 2016-01-07 08_45_16-carburetor diagram ford 4000.docx - Microsoft Word.jpg See item 12 in the attached picture. I guess I will purchase a jet with a # 8-32 thread and give it a try. There seems to be so much info on MS carbs, but I can't find info on this one. I can always resize the hole if the info someday surfaces.
   / 1964 Ford 4000 4 cylinder repair/restore #14
Maybe this will help.
Click on “jets”, to the right. Then click on “diagram” to find the part number, and then you can click on “jets” to see if they have what you need.
TSX-813 Carburetor Info Page
Thanks MMagis, they show 3 different power jets, but are not specific to the TSX-813. I will call them. I appreciate the link and your time!
   / 1964 Ford 4000 4 cylinder repair/restore #16
In the diagram/link that MMagis posted, it looks like item #27, "Seat - Power Adjusting Needle" would thread into the hole you show in your photo, but apparently it is only applicable for "Type B" carbs. Is yours a Type B? If so, it would have the adjusting needle in the top half of the carb body. If not, it would likely be plugged. Either way, with nothing in there, it would sure explain a lot about poor performance!
- Jay
   / 1964 Ford 4000 4 cylinder repair/restore #17
Thanks for all the info gents. It is definitely not a drain plug. it is threaded hole inside the carb.View attachment 452867 See item 12 in the attached picture. I guess I will purchase a jet with a # 8-32 thread and give it a try. There seems to be so much info on MS carbs, but I can't find info on this one. I can always resize the hole if the info someday surfaces.
Interesting how that's all wrapped up and around that fuel shutoff solenoid. Can you tell if its a jet or a plug in there now?
   / 1964 Ford 4000 4 cylinder repair/restore #18
OP's problem is that there is NOTHING in there now.
- Jay
   / 1964 Ford 4000 4 cylinder repair/restore #19
- Jay
By the picture he posted it appeared to be plugged. If it was open the bowl wouldn't hold any gas.
the threaded hole goes from he bowl into the opening for the shaft for the adjusting needle. It is NOT a drain! The tag on the carb says TSX813 63 G. The main adjusting needle shaft enters from the bottom of the carb, not from the inside pointing down as the diagram that I attached on 1/7 9:01am
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2000 International Log Truck, Triaxle, Log Bunks (A52384)
2000 International...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
Jack Daniels Sign Decor (A51694)
Jack Daniels Sign...
