1964 ford 2000 with no reverse
/ 1964 ford 2000 with no reverse #1
Tim Boyd
croswell michigan
ford 6610
I just aquired a f 2000, all of the 4 forward gears work as they should except reverse. Is this a common problem????.
/ 1964 ford 2000 with no reverse #2
I don't know. Sure you looked in the right place? R isn't where it is on the later tractors.....down and a little right of center. It's up and a little left of center. If you go over to the left too far you will hit first. No biggie to pop the tranny cover and have a look see. Shifting fork may be worn but I'd bet you just didn't hit the sweet spot.
/ 1964 ford 2000 with no reverse #3
I have a 1957 ford 851 and on prety much all the 800 series tractors the R is the weak link.
/ 1964 ford 2000 with no reverse #4
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
Blue Diamond Brush Cutter (A64126)
Blue Diamond Brush...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
Gehl RS6-34 (A64119)
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2022 EZ-GO ELITE...
