1959 Ford 861 carburetor problem HELP!
   / 1959 Ford 861 carburetor problem HELP! #1
59fordselectospeed
Hamilton, Ohio
1959 Ford 861
I have rebuilt my carburetor and it will not suck gasoline into the manifold. I took the top off the carburetor and the bowl has gas in it. I spray starting fluid in the maniforl and the tractor runs strong until it burns that up. I have lost vacuume or draft or some such as that. Can anone help?
Thanks
timothymcguire@rocketmail.com
   / 1959 Ford 861 carburetor problem HELP! #2
Do you have reason to believe that there is a vacuum leak? It would have to be pretty serious to not run at all. Is your main jet needle adjusted to 1.5 turns off the seat?
Is there a chance I have the wrong jet? I bought the carb from a tractor junk yard and rebuilt it.
I do not think the manifold has a leak because I spray starting fluid into the manifold on the carb side and it will run.
   / 1959 Ford 861 carburetor problem HELP! #5
Are you sure the main jet is clear?
   / 1959 Ford 861 carburetor problem HELP! #6
that would be my guess.
either venturi is instaleld wrong ( missing?).
carb halves gasket gone.
or mainjet is plugged.
Swict 66" Skidloader Bucket (A50774)
Swict 66"...
1995 Polar Tank Tanker Trailer (TITLE) (A50774)
1995 Polar Tank...
2016 GMC Savana (A50120)
2016 GMC Savana...
2003 Pierce Tilt Cab Pumper Fire Truck (A50323)
2003 Pierce Tilt...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2014 Bobcat 5600 Toolcat (RUNS) (A50774)
2014 Bobcat 5600...
