1959 Ford 861 carburetor problem HELP!
/ 1959 Ford 861 carburetor problem HELP! #1
59fordselectospeed
Hamilton, Ohio
1959 Ford 861
I have rebuilt my carburetor and it will not suck gasoline into the manifold. I took the top off the carburetor and the bowl has gas in it. I spray starting fluid in the maniforl and the tractor runs strong until it burns that up. I have lost vacuume or draft or some such as that. Can anone help?
timothymcguire@rocketmail.com
/ 1959 Ford 861 carburetor problem HELP! #2
Do you have reason to believe that there is a vacuum leak? It would have to be pretty serious to not run at all. Is your main jet needle adjusted to 1.5 turns off the seat?
Is there a chance I have the wrong jet? I bought the carb from a tractor junk yard and rebuilt it.
I do not think the manifold has a leak because I spray starting fluid into the manifold on the carb side and it will run.
/ 1959 Ford 861 carburetor problem HELP! #5
Are you sure the main jet is clear?
/ 1959 Ford 861 carburetor problem HELP! #6
that would be my guess.
either venturi is instaleld wrong ( missing?).
carb halves gasket gone.
or mainjet is plugged.
