1955 Model 640 Oil leak
   / 1955 Model 640 Oil leak #1
MGBBob80
Howell, MI
Ford/640
I'm experiencing an oil leak and having difficulty identifying where it's coming from. Part of that problem is the engine is very dirty right now and I'm getting ready to clean it up, but would like to know where the leak is coming from before I start taking it apart. The oil is dripping on the floor just below the generator. I can see it pooling in the cavity below the pulley attached to the crankshaft, but don't see it leaking from anywhere in particular. it's also collecting on the ledge that the oil pan bolts up to. Again, this is only on the left side of the engine (facing toward the front). Are there any routine trouble spots that I should be looking for? Bob
   / 1955 Model 640 Oil leak #2
Could be the front seal as it is running it slinging it around
Good info that I'll look in to. Off the cuff - tough fix?
   / 1955 Model 640 Oil leak #4
very likey front seal.
medium work.. you'll want the front end off.. might as well address the king pin then and spindles, hubs and axle bearings too. front cover.. gaskets.. pan gasket.. crank seal in cover.. etc.. check governor..e tc..
That's what I expected. Many thanks for your reply!
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
