1955 Model 640 Oil leak
   / 1955 Model 640 Oil leak #1
MGBBob80
Howell, MI
Ford/640
I'm experiencing an oil leak and having difficulty identifying where it's coming from. Part of that problem is the engine is very dirty right now and I'm getting ready to clean it up, but would like to know where the leak is coming from before I start taking it apart. The oil is dripping on the floor just below the generator. I can see it pooling in the cavity below the pulley attached to the crankshaft, but don't see it leaking from anywhere in particular. it's also collecting on the ledge that the oil pan bolts up to. Again, this is only on the left side of the engine (facing toward the front). Are there any routine trouble spots that I should be looking for? Bob
   / 1955 Model 640 Oil leak #2
Could be the front seal as it is running it slinging it around
Good info that I'll look in to. Off the cuff - tough fix?
   / 1955 Model 640 Oil leak #4
very likey front seal.
medium work.. you'll want the front end off.. might as well address the king pin then and spindles, hubs and axle bearings too. front cover.. gaskets.. pan gasket.. crank seal in cover.. etc.. check governor..e tc..
That's what I expected. Many thanks for your reply!
20" Sea Container (A47384)
20" Sea Container...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2005 MACK CV713 (A53843)
2005 MACK CV713...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
