1953 (?) IH
/ 1953 (?) IH #1
MarEng
Willis, TX
Branson 3510 Ford 3000
I have been given an old IH by my father in law. (Yes, I know - I thought he was pretty cool before he gave me the tractor.) He thinks it's a 1953 model. Where would I look to find a serial number, or other confirming mark? Once that's done where would I find a manual (operator's at least)?
When he parked it two years ago it was running but not powerful enough to get rolling with the belly mower attached and running. Once I get it running again I'll check the timing and then most likely end up doing at least a head job.
The belly mower is driven by a convoluted belt system and the lift arms are forward of the operator's seat. Anybody have any experience converting to a 3-pt arrangement?
/ 1953 (?) IH #2
/ 1953 (?) IH #4
By the way.. that H is an awesome tractor if you can get it running right. i missed a chance on a good runner and kick myself to this day. had the same belly mower and big pully/belt setup.
The forward rockshaft is similar to what my cub has for hyds.
There are heavy 3pt aftermarket kits available. I priced one one time inthe 490$ range.. say.. 6ys ago. Hit a antique tractor mag.. there are always adds for the 3pt conversion in there.
Red power is a good magazine. if you need a repair manual.. look for an I&T.. they are pretty decent for basic to moderate stuff.
You may get lucky and it only needs a tune up.
Keep us up to date.. pics are appreciated!
Soundguy
/ 1953 (?) IH #5
Chris. it doesn't sound like an H to me if it has lift arms in front of the operator, more likely an A/Super A, or C/Super C.
I saw the pics of your 661 with the 1 arm loader. That is a share looking tractor. I used to have a 63 2000 with the one arm loader and that was a pretty good combo. Mine had the up and down 5 sp, and that was the easiest loader to take off and put on I've ever had
/ 1953 (?) IH #7
Bad eyes.. I thought he said he had an 'H' now I see it was printed as IH. I figured it was some sort of add on hyd setup.. etc.
Yep.. that stacked 5 speed was a bit hard to get used to. I liked the regular ford 4-spd setup.. but am now used to the semi 'shuttle' aspect of the 5spd with 3rd and rev across from each other..
Soundguy
/ 1953 (?) IH #8
My brother in law has an H and it pulls pretty decent for its class. He usually ends up in at least the top 3.
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
Lowe Quick Attach Post Hole Digger (A66285)
Lowe Quick Attach...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2020 Deere 544L (A60462)
2020 Deere 544L...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
