1952 serial number with front distributor
   / 1952 serial number with front distributor #1
jbasbury
Sanderson
1949 ford 8n
i cracked the block on my 49 8n, so i picked up a somewhat complete 9n for $200 planning to rebuild the engine and put it in my 8n, checking the serial number ♢8n-456915♢ but it has a front distributor, (i'm confused) any ideas?
it has the timing hole in the bell housing and the later position for the oil tube
is it possible someone has swapped the cam and front engine cover to use a front distriutor
   / 1952 serial number with front distributor #5
Anything is possible as folks did what that had to in order to keep the tractors going
   / 1952 serial number with front distributor #6
Agreed.. franken tractors are possible.
Tool Box with miscellaneous items (A53117)
Tool Box with...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
Lincoln Electric DC-400 Welding Machine (A53117)
Lincoln Electric...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
