1952 8N Side Mount Distributor Oiler Question?
/ 1952 8N Side Mount Distributor Oiler Question? #1
mo8N4me
Missouri Ozarks South Central
1952 Ford 8N - 1955 860
First Post at TBN. Hello,:D
Has anybody found a modification repair for a broken or missing oiler on a 1952 8N side mount distributor?
I'm rebuilding my distributor and the oiler was missing and the hole packed with dirt.
I was wondering if a zerk fitting similar to the zerk steering box mod would work as an alternative to the $15 OEM luber?
Also, how does the lube fitting work? I know there is a wick down in the hole, but how does the bushing get the oil?
/ 1952 8N Side Mount Distributor Oiler Question? #2
not worth a 30$ re-engineer to find a way around replacing a 15$ part.
and you already figured it out.. wick action carries the oil.
sounduy
