1952 8N carb issue
   / 1952 8N carb issue #11
Cleaned carb and added fresh fuel. Ran rough for a few seconds then died. Wont crank now, just sputters.
won't crank? that's a starter and or electrical / connection problem. address that first.
All carb holes cleaned, carb reassembled. Ignition check next. What is baffling is it went from running fine to this, no signs of an issue.
ignition check next? BACKWARDS
ALWAYS, ALWAYS, ALWAYS check spark first before doing anything else.
I should have been more clear than wont crank. It sputters, wont stay running. I will pull dist cap tonight and check things.
   / 1952 8N carb issue #13
post back...
Soundguy said:
post back...
Got it running, but like before, rough and on choke only. Spark is good, all checked fine in dist. Between my truck and tractor, I am done with Ford products for today!!
   / 1952 8N carb issue #15
IF spark is good and only runs on choke.. then yo have a fuel delivery problem....
Do you reccomend rebuilding current carb or just replace? I had it apart last night, looks pretty simple.
   / 1952 8N carb issue #17
They are simple just be sure to be patient and meticulous. I doubt you need a new one just a really clean one.
   / 1952 8N carb issue #18
Ditto what Loadstar says, don't buy new just rebuild...make sure everything is clean and clear. If you can find someone that has a bucket of that carb cleaner you soak in, would be worth a couple hours in that.
   / 1952 8N carb issue #19
ditto.. rebuild...
Soundguy said:
ditto.. rebuild...
Update- tractor is running, actually better than ever. I pulled the carb today and cleaned it thoroughly with carb cleaner. I sanded the needle seat and cleaned them throughly. The float had a green buildup on them, cleaned those too. Reassembled and adjusted fuel/idol. Runs great. Thanks again everyone for all the help. Much appreciated!
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
2009 Chevrolet TrailBlazer Multipurpose Vehicle (A51694)
2009 Chevrolet...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
New Holland TN60A (A50120)
New Holland TN60A...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
