1952 8N carb issue
   / 1952 8N carb issue #22
Glad you got her running again. Those carbs are about the simplest carbs in the world to work on and adjust.
   / 1952 8N carb issue #23
yep.. all but the worst rusted and pitted are rebuildable
   / 1952 8N carb issue #24
I'd try using some Sea Foam. It has straightened out carburetor problems on my old Gravely when I had it and a couple older lawn mower engines and generator engine.
Ralph
   / 1952 8N carb issue #25
i look at sea foam like this.
While it may not help.. it SURE will not hurt. and if it even only helps a lil.. I'll take it.
I've used it in small engines with good results too. never any horror stories.. etc..
I use marvel mystery in the 8N and other gas engines. I had a 350 in a truck that had a lifter that had trouble priming. I changed the oil, added a quart of mmo to the crankcase and lifter quited down. Unfortunately sold the truck before I could change the oil again to see if it was a permanent fix. Never used seafoam, what exactly does it do??
   / 1952 8N carb issue #27
those spin on adapters look nice.. care to share the part # and where you got them?
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
UNUSED AGT SDA-140T LOADER (A51243)
UNUSED AGT...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
Bush Hog (A50322)
Bush Hog (A50322)
