1950 Ford 8N - Fuel assembly.
   / 1950 Ford 8N - Fuel assembly. #1
Rick230
Covington, LA
Ford 8N 1950
I have a 1950 Ford 8N Tractor.
I've ordered a new in the box fuel assembly.
I have two questions:
1: When I remove the old fuel assembly from the tank, I wanted to put something on the threads,
like Teflon tape, Do they sell one that is use for a gas engine? If so what color is it?
2: Also when the gas tank is drained, how can I clean it out?
Thanks,
Rick
   / 1950 Ford 8N - Fuel assembly. #2
You can use regular teflon tape (it's pretty inert stuff) or a special sealant that's compatible with fuels. Your choice.The only drawback with tape is it often shreds a little on installation and some pieces can get loose but your sediment bowl assembly should have a filter ahead of the sediment bowl that would catch that stuff.
   / 1950 Ford 8N - Fuel assembly. #3
car parts the tank, I wanted to put something on the threads,
Thanks,
Rick
hello I need to buy new box fuel assembly. How much will it cost and what is the reliable source to purchase it?
Thanks Jerry, I'll take a ride to the auto parts store and pick up something which will work.
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54313)
2014 FREIGHTLINER...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
10,000 PSI AIR HYDRAULIC PUMP (A53843)
10,000 PSI AIR...
