1950 Ford 8N - Fuel assembly.
/ 1950 Ford 8N - Fuel assembly. #1
Rick230
Covington, LA
Ford 8N 1950
I have a 1950 Ford 8N Tractor.
I've ordered a new in the box fuel assembly.
I have two questions:
1: When I remove the old fuel assembly from the tank, I wanted to put something on the threads,
like Teflon tape, Do they sell one that is use for a gas engine? If so what color is it?
2: Also when the gas tank is drained, how can I clean it out?
Thanks,
Rick
/ 1950 Ford 8N - Fuel assembly. #2
You can use regular teflon tape (it's pretty inert stuff) or a special sealant that's compatible with fuels. Your choice.The only drawback with tape is it often shreds a little on installation and some pieces can get loose but your sediment bowl assembly should have a filter ahead of the sediment bowl that would catch that stuff.
/ 1950 Ford 8N - Fuel assembly. #3
car parts the tank, I wanted to put something on the threads,
Thanks,
Rick
hello I need to buy new box fuel assembly. How much will it cost and what is the reliable source to purchase it?
Thanks Jerry, I'll take a ride to the auto parts store and pick up something which will work.
