1949 Ford 8N resto project
/ 1949 Ford 8N resto project
Finally on my way home today. SOH said I have a garage full of boxes that need to be taken care off ASAP :laughing:
Because this one is such a mix and match I decided to just keep it so I will be replacing a lot of parts with new/aftermarket to make it a solid working tractor and also look really good.
The bad news 700 for the tractor and over 2000.00 worth of parts and tires later I will definitely be in the hole, but it will be solid and should last for many many more years:cool2:
Will post some pics later this evening.
Also to update, we did use TSC paint on the other 8n, this one will be done with New Holland red and Tisco medium grey.
SOH is happy since all the boxes have been cleared out.:laughing: and a view of some of the parts. I am really looking forward to a full day in the shop tomorrow. So much to do:confused2:
/ 1949 Ford 8N resto project #24
wow.. lotsa stuff!
Made some progress today. Still in the deconstruction phase but overall a lot accomplished. I managed to find a pair of script fenders and some doglegs that are all in fantastic shape so it will be easy to bring up to par. Also, the Tisco TP 240 medium gray and the rim, silver and hardener arrived:cool2:
Bad news, manifold is showing serious pitting on the after end nesr cylinder number 4:thumbdown: Going to look into resurfacing but more than likely will have to be replaced:mad:
Will be picking up the red paint at the local Ford dealer in Ocala tomorrow morning and hope to get back quickly as I plan to do the rear end seals and brakes and possibly get started installing the Sherman Combo tomorrow....gonna be another long day.
Say, soundguy, guess ya know we are in for a wet weekend in Florida...ya feel like coming over and lending a hand:D willing to feed you and yours well if you can make it.
Will update tomorrow.
/ 1949 Ford 8N resto project #26
You actually aren't far away at all. 45 m maybee ;)
Unfortunately I work.. Errr.. Fortunately I have employment, but said employment is tiring me up :)
As I type this, it just poured here outside ( at work ).
/ 1949 Ford 8N resto project #27
If you know anyone with a mill and a big shell cutter you can give that a shot at the resurface. Did that with both manifolds on my Ford 5500.
Thanks, LD1 I am looking at local machine shops to see if it can be saved.
Managed to make a little progress in the last couple of days. A long time friend and a brother to one of my dearest friends passed away this morning so morale is a bit on the low side but life goes on. He will always be cherished and remembered. If you get a chance, have a toast in his memory..RIP Skip Robinson...I am going to miss you my friend.
Managed to strip and prep the hood, doglegs and fenders for sheetmetal work. Painted the gas tank, front rims and did a little prep work on some small parts. The basket is starting to come along. Hope to start on the brakes and the Sherman in the next couple of days.
Hoochy
Brakes are done. Front axle shim washers and bearings arrived. Spindles are ready to assemble with new bushings and thrust bearings and all spindle bearings and seals. Got the front tires swapped over to the new rims and had new tires installed on the rears.
I need to get it back into a rolling mode so I can move it out of the garage and into the other shed to finish stripping all the old paint from the main body and hopefully split it and install the Sherman.
/ 1949 Ford 8N resto project #31
looking good
Finally heading home and 2 weeks off to work on tha "basket". Tomorrow we send the engine to the machine shop and install the sherman. Then some more prep work ane sheet metal prep. Hope to get a lot done this time around.:cool2:
Sherman is in and made a lot of progress on a lot of small parts, sanding, priming etc. Can't wait to get the engine back so I can get it back to rolling so I can take it to the blasting shed to get it finished. Guess I will just have to work on the other million pieces and get em ready for paint...LOL
Somebody must have been in this basket not long ago because the tranny gears and bearings are spotless. Look at the jack shaft I just took out and the sherman took it's place, bearing and gear are brand new, just like a lot of the gears and bearings in the tranny:cool2:
Is about time the basket gave me some positive encouragement, instead of the usual, this is wrong or worn and you have to replace it:dance1:
Another long day ahead tomorrow.
A couple pics of the TO 40 we worked on last year. I know, THE PAINT!.... is what the owner wanted.
Six days of working darn near daylight till dark:cool2:
And some grey parts from today's paint session. I decided to do it all, even the paint. My first at this paint thing so I hope it all ends well. I fired my painter LOL
Ready to roll back in the shop for final assembly. I am tired...:laughing:
Pic did not load up??
/ 1949 Ford 8N resto project #40
Looks good. Now you are rolling. All the small stuff will take a little time but now you can see the light at the end of the tunnel. A steering wheel might help maneuver it back into the shop.
Kirk
