1948 JD A
/ 1948 JD A #1
Haylough
Rogers,Mn
Kubota3410 John Deere A
Hi, newbie here, need a little help, I was passed down a JD A (1948) hasn't run for 3 yrs some one stole sediment bowl and fuel line, so I replaced those, got it running, shut off to add more fuel to drive it around. When I restarted it, I took off the seat when I was starting it, and noticed the post on battery were smoking when I engaged the starter. I filed and wire brushed the connections but still smoked on engagement. Thought my father in law told me it was converted to 12 volt system but not 100% sure of that. It did start when hooked up negative to ground. If can help me out, thank you.
/ 1948 JD A #2
:welcome:
To the TBN forum. We are glad that you joined with us here.
I am sure that someone here will be able yo help but I can't.
We would all love to see some pictures of that old iron if you could post some.
/ 1948 JD A #3
Sounds like it is drawing too many amps. What condition are the cables in? Check and clean the connection on the ground wire where it connects to the frame/engine.
/ 1948 JD A
Thx, yep I'm replacing both cables.
/ 1948 JD A
Hi, I replaced the positive ground cable, No smoking cable connections, the 48 A started ran good, thx for help all.
/ 1948 JD A #9
And '48 was 12v from the factory.
Rick,
At one time I really wanted an A and looked at several. Were they the ones with two six volt bateries under the seat, wired in series to make 12 volts?
SDlanch SDLGC8 Electric Golf Cart (A64912)
SDlanch SDLGC8...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2012 DRAGON 165BBL ALUMINU VAC TRAILER (A67714)
2012 DRAGON 165BBL...
2022 Deere 325G (A64911)
2022 Deere 325G...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
John Deere Z930M (A64912)
John Deere Z930M...
