1940's Allis Chalmers Tractors (2)
   / 1940's Allis Chalmers Tractors (2) #12
They look to be in decent condition!
Soundguy
   / 1940's Allis Chalmers Tractors (2) #13
Are they what is referred to as butt ugly? sure would like to have one.
   / 1940's Allis Chalmers Tractors (2) #14
But ugly? Surely not! They look kinda like big powered roller skates!
Soundguy
   / 1940's Allis Chalmers Tractors (2) #15
DavesTractor said:
I've found a very clean "G" here in California. Sheetmetal is perfect, straight and no rust, engine is stuck. Tires are poor. One weld on one of the steering arms if I recall correctly. Anyone venture a guess what I should pay for it?
Dave:
Some time ago in another TBN thread I ventured an opinion on a vintage tractor with a good engine, I think it was an 8N, that I said was worth $500-600. Someone, who apparently knows a lot more about tractor haggling than I, responded and told me that any tractor that's running is worth at least $700. So I suppose, with a stuck engine, that "G" you're looking at is worth $700 tops, if you buy into this line of reasoning.
   / 1940's Allis Chalmers Tractors (2) #16
flusher said:
Dave:
Flusher, that might be good logic, and I was thinking along the same lines as far as value, but the "G" is a very unique machine. This makes it desirable if it is real complete and straight, which this one is. Fairly worthless by modern standards, but very high in the "what the heck is that" category. I could put a belly blade on one and use it to grade the lot, giving it some real usefulness.
   / 1940's Allis Chalmers Tractors (2) #17
Even as a non running 'parter' the major components should be worth 1000$ easy.
The intact hood, intact rear cowl, and intact fenders should bring 100-150 Hood, 75$ cowl, 35- 50$ fenders each.
genny, starter, head.. pan.. valve cover, block core, if not cracked and in 'bor-able' condition... trans.. especially if parted.. front housing.. tube frame.. nose.. front axle.. steering box and tube.. rims, hubs.. axle and trumpets ( with brakes ).. etc.. Gas tank.. radiator.. etc... Pile o' money setting there if they are not rotted and rusted out hulks..
Soundguy
   / 1940's Allis Chalmers Tractors (2) #18
Like I said when this thread started. It is very collectible. Buy it, put the diesel in it, use it and who knows, maybe one of today's tractor companies may see it (especially on your lot), and create another G! Let us know when you get it back to the lot....(I'm thinking ahead here.....) BobG in VA
   / 1940's Allis Chalmers Tractors (2) #19
BobG_in_VA said:
maybe one of today's tractor companies may see it (especially on your lot), and create another G! BobG in VA
Check out Home (saukville tractor)
   / 1940's Allis Chalmers Tractors (2) #20
The Saukville is a dead ringer for the modern day "G". Clever of them, I hope they sell well.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
