1920 missing a little
/ 1920 missing a little #1
AlbionWood
Albion, CA
Ford NH 1920
Ford NH 1920 with Shibaura N844 engine, has always started and run smoothly, but just recently began running a little rough, like one cylinder is occasionally missing. Hoped it was just bad fuel or moisture in the sediment bowl, so I cleaned the bowl and drained out the fuel tank, put Seafoam in the sediment bowl and new fuel in the tank. Starts fine and idles fine, but at 1500-2000 rpm it still misses just a little. I tried loosening the injector compression nuts one by one, bleeding each line, but that didn't seem to change anything. The engine isn't misfiring on every revolution, so that operation didn't indicate whether one injector was causing the problem. My question is whether this sounds like a faulty injector, or something else?
If it's an injector problem I will try to get a new set and replace them all at once - they don't look that expensive, the tractor has been cheap to run for many years, and I can't imagine life without it now. But I'd like to know if there is more I can do to diagnose the problem.
/ 1920 missing a little #2
Did you check the air filter and air intake path for partial blockage? Also, make sure the breathing hose from the valve cover is fully open.
/ 1920 missing a little #3
You might try adjusting the valves. Not a guarantied fix for anything other than peace of mind.
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
New 4-Wheeler Tires (A65640)
New 4-Wheeler...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2023 John Deere Z994R (A64127)
2023 John Deere...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
