1920 ford
/ 1920 ford #1
teegarden
1920 ford
Can I buy telescopic stabilizers to fit 1920 Ford tractor? Not sure where to ask this question
/ 1920 ford #2
How about starting with some photos and a description of what you're trying to achieve.
Are you wanting shock absorbers?
Is this a Fordson? Or a Doodlebug?
Most tractors, even modern ones have a unsprung pivot on the front axle that allows the wheels to follow the ground contour. Rear axles are solid with the transmission/differential.
My 1926 Model T Ford had a type of aftermarket spring shock absorbers on it, but without the oil part that modern cars have.
/ 1920 ford #3
LOL I think he is talking about a Ford model 1920 made in the late 80's thru early 2000's. My 1920 is the one on the left in my profile pic.
Are you talking about the stabilizers for the 3 point arms? or the lift arms themselves?
/ 1920 ford #4
Adjustable 3pt hitch links? Are they somewhat universal if one gets the right length and weight rating?
Any local tractor junkyards to browse?
/ 1920 ford #5
He's probably asking about replacing those awkward turnbuckles that stabilize the lower arms with telescoping square tubing with cross holes and pins.
/ 1920 ford #6
/ 1920 ford #7
To be honest I havent paid attention to how the ones on my dads new to him t1530 attach to see if they could be retrofitted to a 1920. I would imagine so as so much of these machines are the same or very similar.
/ 1920 ford #8
I've been using the old original PITA stabilizers since 1991 on mine:) 'Bota style telescoping would be more fun.
Most of the stuff I pull with it is light enough to manhandle and loosen/tighten only one side for on and off.
PORTA POTTY (A68842)
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
TANK MANIFOLD (A67714)
2002 FORD E350 CARGO VAN (A66091)
2002 FORD E350...
2009 JACK COUNTY KILL TRAILER (A67714)
2009 JACK COUNTY...
