1900 oil bath pan
   / 1900 oil bath pan #1
Oakley
2002 Kubota BX2200
I am having a heck of a time removing the oil bath pan. The ring is completely off, the front of the pan drops, but I can't get it loose from the back. Any tips?
   / 1900 oil bath pan #2
Is this on a New Holland or Kubota? The only "oil bath" pan I know of on any tractor would be the cup on an "oil bath" air cleaner. On my old Farmall C, once you get the clamp ring off, it pretty much drops straight down.
   / 1900 oil bath pan #3
I would use a rubber mallet and beat the cup after the holder ring is removed. I think it is just gummed up. might use a heat gun to heat the filter cup to loosen hard dried up oil. It is oil and dirt can get trapped in the cup.
   / 1900 oil bath pan #4
Heat gun and oil, that should go well together.....Tap it with rubber mallet as was stated above, or chase around mating rims with fine blade screw driver to loosen it up. I've been here before, the IH3444 is oil bath. Oil baths are about the most excellent air filtration older systems.
   / 1900 oil bath pan #5
My 1900 oil bath air cleaner system works great. The rubber oil ring gets a little funny and have to bang it off with a rubber mallet but otherwise no issues. And the oil in there really isn't very dirty. The filter material gets dirty (metal screening). I use a solvent and air and wash it out well with water and dry it before reinstalling. Some dirt really comes out of there.
Steve
   / 1900 oil bath pan
Ok I'll get out the rubber mallet, don't have a heat gun , lost a lot of things in hurricane Harvey.
   / 1900 oil bath pan
It's a Ford 1900.
   / 1900 oil bath pan
Got the pan off, thanks for the tips. Is this a normal amount of sludge? It was a bit lower than the full marker, not sure when the PO last changed, but I've spent around 8 hours on it brush hogging 5' weeds in the pasture and grading the driveway. 20180722_161015-1536x864.jpeg
   / 1900 oil bath pan #9
Looks like it hasn稚 been cleaned in a pretty long time. On mine if I change it yearly it痴 pretty clean overall. Takes about three years for it to actually get even somewhat black and dirty. Remember it痴 not oiling any moving parts to get black. It痴 only air that draws the oil into the strainer filter and then transferred the dirt to the oil.
   / 1900 oil bath pan
Wow, that long, shame on them.
2006 Chevrolet Express 2500 Cargo Van (A51692)
2006 Chevrolet...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
New/Unused 2025 H12R Mini Excavator (A51573)
New/Unused 2025...
