18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #11
That was a couple of years ago...........don't recall having to adjust the carb.
Did it run better..........?.......eh.........maybe...........sounded great though.
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #13
Check the governed RPM. Increase it by a couple hundred RPM to produce more power. Just about everything will shorten the engine life. You can go to sythetic oils to increase protection?
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #14
I think I'd just have the heads shaved about 0.030 - bumping the compression ratio about 1/2 pt. You'll see a difference then :)
2008 FORD F-750 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-750...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 Peterbilt 389 Wet Kit T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
Case Titan 3530 (A56435)
Case Titan 3530...
