18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #11
That was a couple of years ago...........don't recall having to adjust the carb.
Did it run better..........?.......eh.........maybe...........sounded great though.
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #13
Check the governed RPM. Increase it by a couple hundred RPM to produce more power. Just about everything will shorten the engine life. You can go to sythetic oils to increase protection?
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #14
I think I'd just have the heads shaved about 0.030 - bumping the compression ratio about 1/2 pt. You'll see a difference then :)
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2019 FREIGHTLINER SD122 DAY CAB (A57880)
2019 FREIGHTLINER...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
skid steer mount 3 point attachment (A56857)
skid steer mount 3...
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
