1863 blows 20amp fuse as soon as key is turned on
   / 1863 blows 20amp fuse as soon as key is turned on #1
TomH5304
I have traced my problem to what appears to be an electronic component on the left rear engine housing. It's flat, & has 3 wires clipped to it and a ground wire under 1 of the 2 screws. When I unplug the 3 wires the fuse no longer blows.
Any idea how to isolate if my problem is this component or something on a wire past this component?
I'm running out of fuses....:)
   / 1863 blows 20amp fuse as soon as key is turned on #2
That could be the problem as that is a regulator.
   / 1863 blows 20amp fuse as soon as key is turned on #4
I drag home another old tractor or motorized thing I don't need and my Wife does the same thing!!:D (J/K!)
Before you go buying a new rectifier/regulator (~$90) closely examine the wires and connections for a possible short-circuit to ground.. maybe a wire is shorting out to the engine frame when the plug is in the 'plugged in' position. Always check the cheap fixes first!:cool:
2019 TerraGator 7300 Spinner truck (A55315)
2019 TerraGator...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
Sterling 9500 (A55315)
Ikonx Zero-Turn Mower (A56857)
Ikonx Zero-Turn...
2015 International Bucket Truck (A55973)
2015 International...
