1863 blows 20amp fuse as soon as key is turned on
   / 1863 blows 20amp fuse as soon as key is turned on #1
TomH5304
I have traced my problem to what appears to be an electronic component on the left rear engine housing. It's flat, & has 3 wires clipped to it and a ground wire under 1 of the 2 screws. When I unplug the 3 wires the fuse no longer blows.
Any idea how to isolate if my problem is this component or something on a wire past this component?
I'm running out of fuses....:)
   / 1863 blows 20amp fuse as soon as key is turned on #2
That could be the problem as that is a regulator.
   / 1863 blows 20amp fuse as soon as key is turned on #4
I drag home another old tractor or motorized thing I don't need and my Wife does the same thing!!:D (J/K!)
Before you go buying a new rectifier/regulator (~$90) closely examine the wires and connections for a possible short-circuit to ground.. maybe a wire is shorting out to the engine frame when the plug is in the 'plugged in' position. Always check the cheap fixes first!:cool:
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
