1863 blows 20amp fuse as soon as key is turned on
   / 1863 blows 20amp fuse as soon as key is turned on #1
TomH5304
I have traced my problem to what appears to be an electronic component on the left rear engine housing. It's flat, & has 3 wires clipped to it and a ground wire under 1 of the 2 screws. When I unplug the 3 wires the fuse no longer blows.
Any idea how to isolate if my problem is this component or something on a wire past this component?
I'm running out of fuses....:)
   / 1863 blows 20amp fuse as soon as key is turned on #2
That could be the problem as that is a regulator.
   / 1863 blows 20amp fuse as soon as key is turned on #4
I drag home another old tractor or motorized thing I don't need and my Wife does the same thing!!:D (J/K!)
Before you go buying a new rectifier/regulator (~$90) closely examine the wires and connections for a possible short-circuit to ground.. maybe a wire is shorting out to the engine frame when the plug is in the 'plugged in' position. Always check the cheap fixes first!:cool:
Nissan Forklift (A55973)
Nissan Forklift...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A57880)
2007 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
TANK MANIFOLD (A58214)
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
