1810d lift capacity
   / 1810d lift capacity #1
bish_oz
Brisbane, Australia
Yanmar YM1810d
Hello,
I've just brought on ebay a fork lift attachment for my tractor (see attached):D :D As I have a couple of pallets around I thought it would make a handy carry-all.
Does anyone know what the 1810d is rated to lift? The heaviest implement I own is my Yanmar rotary hoe, which as a guestimate would be around 200kg.
On the saftey front, I guess you follow commonsense and not raise the lift arms higher than you need to when carting things around the yard. Any other tips??
Regards
Bish
   / 1810d lift capacity #2
Be sure you have plenty of counterweight on the rear end. Some type of implement, your hoe, bushhog or such.
Sorry I forgot to mention that this is a rear attachment, ie. attaches to the 3 point hitch arms. Perhaps I'd need counterweight on the front end.
   / 1810d lift capacity #4
I built one similar to use with my Quick Hitch. (And to try out my new arc welder toy.)
http://www.tractorbynet.com/forums/...71849399-pallet-forks-rear-3-pt-p1050892r.jpg
The next picture shows what you can expect to to carry - I'm taking three garbage cans of water down to new trees. That may be as much as 800 lbs. (including the double-weight pallet and deck.) I think the lifting capacity of your tractor would be similar. You are sure to need front ballast.
http://www.tractorbynet.com/forums/...4523073-3-pt-carryall-p00069rwateronforks.jpg
I just noticed the forks on the one you got are about the same height as the three-point pins. You might ask the ebay seller if the forks are low enough to slip under a pallet flat on the ground.
   / 1810d lift capacity #5
Good on the 3pt mount as it will do better than up front. As you can see which model I have, based on rated load capacity of the stk front tires, I'm tech overloaded with nothing in the bucket. With that said, I've pick up a stump that must have weighed about 800 lbs (lifted from x-bar aft of the bucket) and nothing failed but tractor was very light on rear axle.
California - Love your work. An ambitious first project. Looks very heavy duty. Good point about the 3 point hitch location. I didn’t think about that when bidding! I guess if it doesn’t work, I’ll have to bite the bullet and buy myself a welder and start learning… Probably a good first project :)
Thank everyone for your replies. I feel more confident on how much I can expect to lift. Looks like the pallet forks themselves will be the weakest link. They are only rated at 250kg (or 550 lbs).
Having said that, if I do get that welder, I can always strengthen it down the track…
Better start asking the boss (my wife) for more pocket money… ;)
2018 CHEVROLET SONIC (A53843)
2018 CHEVROLET...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2012 International 4300 Reefer Truck (A53473)
2012 International...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
