180 Dragon tractor
/ 180 Dragon tractor
I have the Feng Shou series 180 Operator Instruction Manual available covering Models
FS184---FS184-4---FS180---FS180-4---FS180-3---FS180-2---FS180-1---FS180YS---FS180YSI
37 pages.. copies available $30.00 shipped
Detaled--Features of various Models of Feng Shou Series 180 tractors
this is a owners manual. there is a pic on what is in the manual. this is about the adjustments, troubleshooting, wiring ,specifications, operation, Lubrication and maintenance
this is a pic of the two parts that the tech school made for me to make the pump work on this tractor
made out of airplaine aluminum
never give up figuring out the solution . the end is there somewhere
.I finally got the tractor back from the tech school. they completely rewired the whole tractor. it was a job. the tractor suffered from back yard know it all bad mechanic workmanship.
the only thing to do now is since I changed the hydraulic oil [30w non detergent] and filters [ two ] I need to bleed the hydraulic system. so the 3 point hitch can work .
this Diesel sounds amazing. like its saying I can pull a tree down. I will put it up for sale for $1,500 for just the tractor. not sure if I will increase the price by adding a finish mower with it ..
the down side to these Japanese tractors is the Japanese people are small in size
and as a result there isn't much seat adjustment unless one modifies the seat bracket
this tractor has 8 forward speeds and two reverse with high low shifter
three PTO speeds
vertical ,water cooling, 4 strokes Diesel
I need some help. the hydraulic pump was checked out to work .it was Ok. the problem I have is that there is no fluid moving through the high pressure line. I had been adding fluid through one of the filters. don't have a clue where the proper place is where you add the hydraulic fluid .
/ 180 Dragon tractor #25
Hi Junkers,
So you still have a copy of the FengShou 180 series manual?
Cheers
Hi Junkers,
Cheers
yes I do BUT its $30.00 shipped to USA PO . need your address to see what extra it will cost to Australia
just a follow up with the tractor. I sold it to a guy in Tenn . Not sure what issues he had but noticed he was trying to sell it...BUT I do have very hard to find copies of the manual for sale..
37 pages.. copies available $30.00 shipped to USA PO extra cost to ship out of country. extra cost depends where
/ 180 Dragon tractor #28
Hi Junkers,
Have sent you a PM
Cheers
/ 180 Dragon tractor #29
Hi Junkers,
To Australia, Queensland, Postcode 4124.
Have sent you a PM with full address details.
Cheers
sorry for the delay. didn't get a notice that you replied and no PM but got your postcode # will get back with you asap
I would like to offer this info to those of you that would like to know
how our United States Post Office works sending a envelope with about 15 pages to say Australia
hear is the rub dealing with the US post office
sending a letter size envelope with about 15 pages to Australia WITHOUT the 1 " two prong clip to hold the pages together is $ 10.72
sending it with the small clip is $ 22.75
/ 180 Dragon tractor #34
How much if the pages were just stapled? Or not stapled or clipped at all? I mean the pages are in an envelope, where else are they going to go? How about Fed-Ex? UPS? (Yes, they go there).
/ 180 Dragon tractor #36
Has anyone figured out what Number 20 is on the Wiring diagram?
I am assuming that it is a relay block or something for the lights?
And number 19 in the following wiring Diagram
/ 180 Dragon tractor #39
That's what I thought, considering the amount of inputs and the Key only have four inputs...
78in Caterpillar Skidsteer Tooth Bucket (A65579)
78in Caterpillar...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2006 MACK VISION (A65643)
2006 MACK VISION...
(6) Finger Pickup Meters (A65640)
(6) Finger Pickup...
