180 Dragon tractor
/ 180 Dragon tractor #1
junkers
knoxville,tn
180 Dragon
]Picked up this Dragon tractor for $ 800 . and of course nothing about it on the web .The hydraulic pump was bad and it came
with another pump that was a little different. I dropped that off at a Tech school and their machine shop crafted a mount plate to make the pump bolt up
There is a post I did in the hydraulic section about a problem with IDing the hydraulic filters
It does run but several wires are just hanging there. I wonder if the wiring is the same as the Mahindra FS180 ? I sure could use a wiring diagram.
someone mentioned that one of your members called bluechip might be able to help
the tractor is a feng shou
the diesel is a 2 cyl model J285T made by jiangki
I do want to pass on a bit of part info on Chinese tractor parts I ran across after days of searching. Google new rhino tractor parts
and click on the link
thanks for posting
took the spare hydraulic pump to a tech school and they made up two adapters so I can use this pump. its a little different than the bad pump but it works. then took it to Royal Brass And Hose in Knoxville,Tn and they set up the hose adapters. Problem Solved on that.....
The second issue I had was there was no replacement Diesel fuel line available anywhere for this tractor [ dry rotted] with the ends it had so off to Royal Brass and Hose in Knoxville,Tn I went and they were able to make up a hose using my ends. Problem solved on that....moving right along
Notice the linkage arm under the fuel line in pic--- is that a choke for this diesel Jiangki J285T engine ? its spring loaded
went to the NAPA warehouse in Knoxville,tn with the hydraulic filters . God must be with me today because I talked to a 16 year NAPA Female manager
that took a lot of time in the older filter books . as it turned out she is sending the larger filter to the techs at Wix filters. two to four week reply.
but she found a filter that will work for the small one. But a small alteration is required. very simple. check the pics.
The brand filter NAPA Gold 3507 is a perfect fit. you need to take what I call a all size drill bit shown in pic and drill out the end of the filter because one end is closed.
be careful you don't over tighten the cap or you will screw up the gasket re installing
PS after rechecking the filter cap and seeing how it seals against the filter, I don't think you have to drill out the end of the filter.
/ 180 Dragon tractor #5
took the spare hydraulic pump to a tech school and they made up two adapters so I can use this pump. its a little different than the bad pump but it works. then took it to Royal Brass And Hose in Knoxville,Tn and they set up the hose adapters. Problem Solved on that..... The second issue I had was there was no replacement Diesel fuel line available anywhere for this tractor [ dry rotted] with the ends it had so off to Royal Brass and Hose in Knoxville,Tn I went and they were able to make up a hose using my ends. Problem solved on that....moving right along Notice the linkage arm under the fuel line in pic--- is that a choke for this diesel Jiangki J285T engine ? its spring loaded went to the NAPA warehouse in Knoxville,tn with the hydraulic filters . God must be with me today because I talked to a 16 year NAPA Female manager that took a lot of time in the older filter books . as it turned out she is sending the larger filter to the techs at Wix filters. two to four week reply. but she found a filter that will work for the small one. But a small alteration is required. very simple. check the pics. The brand filter NAPA Gold 3507 is a perfect fit. you need to take what I call a all size drill bit shown in pic and drill out the end of the filter because one end is closed. be careful you don't over tighten the cap or you will screw up the gasket re installing PS after rechecking the filter cap and seeing how it seals against the filter, I don't think you have to drill out the end of the filter.
The spring loaded linkage arm should be for the manual shut down cable or solenoid. Diesels normally don't have a choke mechanism
thanks for the post ditech
where would the linkage cable or rod go to ?
is it a cable that would go to the dash area with a knob that you would pull to shut it down ?
/ 180 Dragon tractor #7
Can you help me? I have same style tractor that i bought. Someone has stole the starter motor from it. Can you please give me the starter part number so i can buy new one? Thanks.
/ 180 Dragon tractor #8
i could look at the linkage and see where it go to on my tractor..
/ 180 Dragon tractor #9
Could you post more engine pics(and starter) of your tractor? "Junkers"
call or E-Mail masters in fl . they should have what you need. I will also get a pic of my starter but you may not need it
Masters Farm Supply Altha,FL
850-762-3221
Good Link Request Rejected {Good Link ]
text-masters7@fairpoint.net
/ 180 Dragon tractor #12
Thanks Junkers... I call them this am and they had one starter that was "heavy duty". I was looking for the original oem starter. Could you please send me a pic and by chance the model number of your starter.
As usual any numbers that was stamped on the ID plate with these old tractors have turned to dust can't help you with that but can show pics of my starter on this 180 dragon
in my thread go here to find old Chinese tractor parts And generic replacements I will post a few crossover part numbers on this tractor
including a wiring diagram that is coming to me.. I will post in a couple of weeks no later. several parts on this tractor are no longer available.but other sizes will work .
there is another Chinese tractor supplier I listed in go here to find old Chinese tractor parts And generic replacements. if you are looking for a OEM starter you may need to ask if they have a used starter
I am not sure what you are showing me. what does the rod have to do with the starter ?
/ 180 Dragon tractor #15
disregard, was thinking I read a post of yours and you was acquiring where the rod connects.
yes you are correct pastorjakes. getting ahead of myself. thanks
/ 180 Dragon tractor #17
Just as you i purchase this tractor from someone else to use it in my garden. It was made in 1993. Cant seem to find much info on it to purchase parts. Was thinking i could later fix it up and overhaul the engine. I really need to find out what QD starter is on the J285t 03 engine... someone stole my starter off tractor. look forward to all info I can obtain on the tractor. I will be looking and share what info I find also. Will be waiting on you other info thanks.
I already posted the info in my thread go here to find old Chinese tractor parts And generic replacements in Chinese Tractors
I think my tractor the 180 Dragon is at least 20 so years old. only bought it to turn a buck or two.
but yours being a 1993 would be easier to find parts for .I would not be to picky on looking for only OME parts because these tractor parts are not made anymore. but shop around because prices are like a roller coaster
I found an original owners manual for the FS 180 dragon tractor being mailed to me.
since this manual cost me some bucks to get I can make a copy of this from my original for a small cost.
just PM me if interested
I have the Feng Shou series 180 Operator Instruction Manual available covering Models
FS184---FS184-4---FS180---FS180-4---FS180-3---FS180-2---FS180-1---FS180YS---FS180YSI
37 pages.. copies available $30.00 shipped
Detaled--Features of various Models of Feng Shou Series 180 tractors
