18 hp kohler
/ 18 hp kohler #1
jud225
league city, tx
allis chalmer
18 hp kohler, old style was ran out of oil. any chance to rebuild it??? jud225
/ 18 hp kohler #2
If it is the 18hp cast iron engine, absolutely. If you are lucky, all you will need is a new rod.
/ 18 hp kohler #3
without taking the head off and checking the cylinder for scoring , no way to tell for sure ....
might be a light seize ( just free things up and away you go ) right up to a full blown welding rings to cylinder walls and a scrapped crank/ rod and piston .... more $$$$ to rebuild than buying another good motor ...
lots of kits available if you can salvage the block /crank .....
207275 (A52708)
207275 (A52708)
2017 Ford F250 (A60352)
2017 Ford F250...
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
2006 Ford F-550 4x4 Venturo ET10K 1.5 Ton Crane Service Truck (A61568)
2006 Ford F-550...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
