18 hp kohler
/ 18 hp kohler #1
jud225
league city, tx
allis chalmer
18 hp kohler, old style was ran out of oil. any chance to rebuild it??? jud225
/ 18 hp kohler #2
If it is the 18hp cast iron engine, absolutely. If you are lucky, all you will need is a new rod.
/ 18 hp kohler #3
without taking the head off and checking the cylinder for scoring , no way to tell for sure ....
might be a light seize ( just free things up and away you go ) right up to a full blown welding rings to cylinder walls and a scrapped crank/ rod and piston .... more $$$$ to rebuild than buying another good motor ...
lots of kits available if you can salvage the block /crank .....
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61567)
2025 BS43 44in...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
New/Unused Landhonor 20ft x 20ft Carport with Side Walls (A61166)
New/Unused...
832733 (A61166)
832733 (A61166)
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
