175 or similar Model Questions
   / 175 or similar Model Questions #1
johndeereg
MD
Cub Cadet 107
I have a 175 Hydro with a Kawasaki engine. The motor makes quite a bit of valve/ticking noise, is that normal? Also there is a pretty loud rattle kind of noise coming from the bottom of the engine. Sounds like a hollow/pulley type rattle/noise. Any ideas on this model? Are there any common sources of noise or problems on these tractors or similar models? thanks for any help
   / 175 or similar Model Questions #2
It's impossible to discuss "noises" without hearing it, but the valves might need adjusting.
Underneath?
I would say to take the belt off the PTO and see if this changes anything for the noise underneath.
If not, then you could take the drive belt off, which would be harder.
If you can isolate the noise you can then decide on replacement or not.
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2015 ISUZU NPR 16FT BOX TRUCK (A51219)
2015 ISUZU NPR...
2015 Nissan Pathfinder Platinum SUV (A50324)
2015 Nissan...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
