1720d front wheel drive problem
/ 1720d front wheel drive problem #1
Eagles eye
Shelbyville, ky
Massey 35
Well, I have removed the cover on the front wheel drive shaft and the front portion where it hooks to the front diff is spring loaded. I depressed it and the shaft came away from the front spline. Two issues....when I move the front spline it is engaging the front wheels so I will assume the diff is good. When I removed the rear part of the shaft from the drop box it has ball bearings that seem to fit in the spline. Again, assuming that is what drives/engages the shaft. The front spline had no ball bearings so now I am noting that this may be the problem with the I operational front wheel drive.
Question, is it common for these balls to fall out over time with wear? If so is it as simple as replacing them and reinstalling the shaft? Also, the output seal on the drop box is leaking oil and there seems to be some metal shavings around the outside, assuming from the ball bearing wearing down in that end of the shaft? Will replace all bearings
W
Also
W
Also
Also, how do I replace the seal in the output of. The drop box?
/ 1720d front wheel drive problem #4
Also look closely at the spring and make sure the balls seat on the shaft as they should, i found the spring broken and mine and while it looked like it was functioning it was not holding the balls tight in position and the eventually fell out.
Just a thought,not sure about the front but mine had balls (6) on each end
Keep us posted
/ 1720d front wheel drive problem #5
You have a good understanding of it. Balls do go front and rear. Do you have a manual or have you seen this parts drawing? Yanmar Tractor Parts: 4WD INTERNAL
You should be able to look at your drop box seal with the drive shaft removed and deternmine whether it can be pulled without removing the drop box from the transmission. Make sure you check the drop box shaft for tightness making sure the bearings are ok.
I really don't know how bad these balls are to wear but I have read of quite a few facing the same senerio you are.
Keep us posted
Good catch on the spring. Mine is in fact broken. Thanks
Thanks.i think it can be pulled without dropping box. I ordered a new seal, rubber covers, ties and balls. When I get the seal it will better tell me if that is the case.
I'll check the shaft play as well. Thanks for the insight.
I looked at he drawing. Think I might order a manual for future use. I gave only had this tractor a month and think its a keeper. Moved 17 ton of gravel last week and dug out about 2000 sf of sod. Going to hook up 5ft finish mower this week to see how it does.
Thinking about ordering turf wheels and tires....any thoughts?
/ 1720d front wheel drive problem #9
I have thought about the turf wheels and tires but $$ get in my way. :drool: Also not fully convinced they would work well with my gardening implements.
That is my concern. I do mow about 4acres of yard and it would ride much better. Just concerned about traction in the garden and snow. Maybe someone with experience with this will respond. $$$ are an issue but my uncle owns a tire store so the wheels would be my major cost.
/ 1720d front wheel drive problem #11
I have a 2020d and I use mine 50/50 turf and woods. I switched to turf tires and had them loaded. Way more stable and works great in the snow. I was digging soil with my box blade this spring with good results. I run chains on mine year round. Even with chains I do not tear up the turf unless I am doing something stupid. The tires made my tractor much more stable which really helps me with a almost 45 degree hill. Plus having the tires loaded helps with loader work too
Thanks. Think I may go this route
Sperry-New Holland 311 Hayliner - Small Square Baler (A66408)
Sperry-New Holland...
IH 18' Cultivator (A66408)
IH 18' Cultivator...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
Landhonor Adjustable Rolling Creeper Stool (A66408)
Landhonor...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
