1720 Green Antifreeze?or?
   / 1720 Green Antifreeze?or? #1
chopped
New England yankeee
Greetings I am helping a friend who had a ford 1720 model tractor.We find green color anti freeze in the unit. But with the post concerns here with 'cavitation' Im concerned that just it haveing a green colar anti freze means its correct.
Does anyone know if it can run the standsand green ?
If I remember correctly its due to a 'wet' cylinder liner?(not sure whats in the 1720)
Thanks ahead of time..:thumbsup:
   / 1720 Green Antifreeze?or? #2
If your not sure that it has DCA, add some yourself. It wouldn't hurt anything. You can pick it up at a Ford dealer. I use it in Our Poweerstroke and all our etractors.
Thanks Jerry we are planning a complete flush out of it. Just wanted to use the gren if it was ok to,..I might just look for the DCA stuff. but woukld stil like to know what it could have .. thanks...
   / 1720 Green Antifreeze?or? #4
I use WixCool #24056 cooling system treatment in my diesel tractor. My understanding is its supposed to prevent all that and its available at most parts stores if you dont have a Ford dealer handy. And yes you just use green AF and add 1/2 pt of this stuff to 2 gallons cooling system capacity.
   / 1720 Green Antifreeze?or? #6
Welcome! That is a bargain even with shipping you are right. :thumbsup:
I just checked what I paid for my last bottle @ OReillys-$6.81 and retail is $15.24, I dont pay tax but that adds $ too.
   / 1720 Green Antifreeze?or? #8
Your antifreeze for the 1720 is regular 50-50 ethylene glycol permanent antifreeze. You need no special additives. The engine is NOT a wet-sleeve cylinder engine. All small Shibaura engines in New Holland compacts use the same 50-50 mix as in cars. Anything additional is a waste of money.
Why thank you Just wahat I wanted to hear.I saw nothing in the manual so I sort of assumed that it was fine. Thanks again.
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
UNUSED CFG INDUSTRIAL XZ20R EXCAVATOR (A51247)
UNUSED CFG...
