1715
   / 1715 #1
zeljko zoricic
i just got the 1715 2wd tractor and need to change fuel filter. do i have to bleed the system and how?
   / 1715 #2
Yes you will have to bleed the system.
On page 32 of the owners manual there are 4 steps.
1. Be sure there is adequate fuel in the fuel tank.
2. Open the fuel shut-off valve.
3. open the bleed screw at the pump and let the air bubbles escape, then close the bleed screw.
4. Push the hand throttle to the high speed position. Turn the engine over for a few seconds to bleed the high pressure fuel tube.
WARNING: Fuel oil in the injection system is under high pressure and can penetrate the skin.
It takes a 10mm wrench for the bleed screw. Remember to clean the sediment bowl before installing the new filter.
Napa part # is 3264
Wix part # is 33264
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
1996 Allegheny 35FT 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
Mini Excavator (A52377)
Mini Excavator...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
7033 (A51691)
7033 (A51691)
