1715
   / 1715 #1
zeljko zoricic
i just got the 1715 2wd tractor and need to change fuel filter. do i have to bleed the system and how?
   / 1715 #2
Yes you will have to bleed the system.
On page 32 of the owners manual there are 4 steps.
1. Be sure there is adequate fuel in the fuel tank.
2. Open the fuel shut-off valve.
3. open the bleed screw at the pump and let the air bubbles escape, then close the bleed screw.
4. Push the hand throttle to the high speed position. Turn the engine over for a few seconds to bleed the high pressure fuel tube.
WARNING: Fuel oil in the injection system is under high pressure and can penetrate the skin.
It takes a 10mm wrench for the bleed screw. Remember to clean the sediment bowl before installing the new filter.
Napa part # is 3264
Wix part # is 33264
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2025 Icon Electric Cart (A51694)
2025 Icon Electric...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2015 MACK PINNACLE (A53843)
2015 MACK PINNACLE...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
Syrup Kettle (A50123)
