1715
   / 1715 #1
zeljko zoricic
i just got the 1715 2wd tractor and need to change fuel filter. do i have to bleed the system and how?
   / 1715 #2
Yes you will have to bleed the system.
On page 32 of the owners manual there are 4 steps.
1. Be sure there is adequate fuel in the fuel tank.
2. Open the fuel shut-off valve.
3. open the bleed screw at the pump and let the air bubbles escape, then close the bleed screw.
4. Push the hand throttle to the high speed position. Turn the engine over for a few seconds to bleed the high pressure fuel tube.
WARNING: Fuel oil in the injection system is under high pressure and can penetrate the skin.
It takes a 10mm wrench for the bleed screw. Remember to clean the sediment bowl before installing the new filter.
Napa part # is 3264
Wix part # is 33264
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2025 JMR Stump Bucket Skid Steer Attachment (A51691)
2025 JMR Stump...
Adams 5T HC Spreader (A53473)
Adams 5T HC...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
