1715 Front Axle Numbers.
/ 1715 Front Axle Numbers. #1
Dataway
Greenfield TN
Ford 1715, BX2200
I've got a leaking seal in my steering cylinder and the parts books call out different parts based on axle production number.
SBA344960440 for axle number 2F31713 or greater
SBA344960206 for earlier axles numbers.
Only numbers I can find on my axle are:
KT1N0100 (last digit could be D instead of zero)
DX24
AM9123
98325
None of these seem to fit the numbering pattern called out. It's a 1995 1715.
Any help appreciated.
/ 1715 Front Axle Numbers. #2
Look at the parts book detail on the cylinders. It shows a measurement from the from the supply tube to the end of the cylinder to determine which cylinder you have.
13mm = SBA344951810 = SBA344960206 KIT
28mm = SBA344952581 = SBA344960440 KIT
28mm = SBA344952610 = SBA344960440 KIT
New/Unused ATS Lifting Motor (A65583)
New/Unused ATS...
3Pt Bale Carrier (A66408)
3Pt Bale Carrier...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
