1710 oil pressure sending unit
   / 1710 oil pressure sending unit #1
Kent B
Tallahassee FL
1984 Ford 1710
I have a Ford 1710 2wd (1984) and I unscrewed the oil pressure sending unit from the side of the engine. No oil ran out.
Is there supposed to be oil making contact there or what.
When I drained the oil from the injector pump (before removing the sending unit) did that have anything to do with this?
I have since replaced the oil in the pump and the crank case.
Maybe I removed the sending unit before I refilled with oil. I don't remember now.
I guess I can take it out again to see if there is oil behind it now.
Thanks.
   / 1710 oil pressure sending unit #2
I think it is above the oil level in the crankcase. It gets pressure when the engine is running. Put it in, hook up the wire and start the tractor. If red light goes out, all is well. Why did you take it out? Is it a new replacement?
   / 1710 oil pressure sending unit #3
Kent,
With the engine off when you take out the sending unit no oil will run out. The sender location is above crankcase oil level. Now if you turn the engine on the story is different with a steady stream of oil shooting out of the sender threaded connection. (don't recommend testing it)
Injector oil pump and the crankcase is not shared on your tractor, so the answer is negatory.
You will have oil coming out only when engine is on.
JC,
I took it out thinking that it was the coolant temp sending unit. Once it was out I realized my error.
Kent,
JC,
Ten - 4
Thanks.
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2000 Toyota Tacoma Pickup Truck, VIN # 5TEWN72N6YZ690085 (A51572)
2000 Toyota Tacoma...
JOHN DEERE 2032R LOT NUMBER 239 (A53084)
JOHN DEERE 2032R...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
