1710 oil pressure sending unit
   / 1710 oil pressure sending unit #1
Kent B
Tallahassee FL
1984 Ford 1710
I have a Ford 1710 2wd (1984) and I unscrewed the oil pressure sending unit from the side of the engine. No oil ran out.
Is there supposed to be oil making contact there or what.
When I drained the oil from the injector pump (before removing the sending unit) did that have anything to do with this?
I have since replaced the oil in the pump and the crank case.
Maybe I removed the sending unit before I refilled with oil. I don't remember now.
I guess I can take it out again to see if there is oil behind it now.
Thanks.
   / 1710 oil pressure sending unit #2
I think it is above the oil level in the crankcase. It gets pressure when the engine is running. Put it in, hook up the wire and start the tractor. If red light goes out, all is well. Why did you take it out? Is it a new replacement?
   / 1710 oil pressure sending unit #3
Kent,
With the engine off when you take out the sending unit no oil will run out. The sender location is above crankcase oil level. Now if you turn the engine on the story is different with a steady stream of oil shooting out of the sender threaded connection. (don't recommend testing it)
Injector oil pump and the crankcase is not shared on your tractor, so the answer is negatory.
You will have oil coming out only when engine is on.
JC,
I took it out thinking that it was the coolant temp sending unit. Once it was out I realized my error.
Kent,
JC,
Ten - 4
Thanks.
Laymor SM450-ST Sweeper (A51573)
Laymor SM450-ST...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
